Bypassing ignition / starter button is the only way to crank over?
Discussion in '4 Stroke' started by Nikolas ortiz, Jul 24, 2024.
  1. Nikolas ortiz Husqvarna
    2013 husqvarna te449
    2007 ktm 250sxf
    Hey yall! I’m very new to the husky interface and just recently bought a used 2013 te449 for really cheap! Yes I have registration and all. Bike was always maintained as it was owned by a guy who previously worked with the husky race team and tricked it out! Then the guy I bought it off of just had the bike and thought he could fix the problem it had occurring which he assumed was the stator and a bad battery, so then he just never got to work on it so it sat for a year and a half then he bought a new bike. Now I have it and the problem that occurs is that it seems like the previous owner had custom did the ignition or snipped from maybe a fall? I charged up the battery and checked the starter relay and seen that the starter wasn’t giving power to the relay and so I replaced the relay and nothing happened. So I checked if there was a ignition switch and sure enough there is one but I didn’t have it so I bought one and tried plugging into some wires that looked like it would fit the match of the plug but nothing happened when I turned over the key. So I tried to bypass the ignition with a wire from the battery straight to the starter relay and it cranked over and the display turned on. So I'm confused onto why the ignition isn’t there or if I should search harder for the wires/plug?
    How do you start the bike? Is there a key you usually turn first to wake up the electronics. Or do u just hit the start button and it turns everything on.
  2. rancher1 Husqvarna
    WA
    Husqvarna quit installing key ignition switches in 2012.
