125-200cc Calling all WRE 125 owners.
Discussion in '2 Stroke' started by paddy.t, Nov 26, 2012.
  1. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Morning,
    Im looking to do away with the autolube and fit a bigger carb. Can anyone suggest a carb that will fitt?
    Also it would be nice to hear of any other mods you chaps have done.
    Thanks
    Paddy
  2. SHY UK Husqvarna
    yes please
    Mikuni TMX 38 carb' from the WR125 would be the obvious choice, surely?
  3. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Yeah it would be, im trying to find out if its possible or would need to change manifolds.
    Cheers.
  4. SHY UK Husqvarna
    yes please
    Or another easy-ish option would be the 38 version of the same vhsb dellorto your bike already has?
  5. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Cheers shy ill have a look into the dellorto 38.
    Im thinking a bigger carb will be a better option than the carb de-restriction kit as im sure i will get better performance increases for around the same £.
    Also does anyone know if the v-force reeds and cage will fit the WRE?
    Cheers.
    utopia likes this.
  6. cooper Husqvarna
    Kent UK
    wre125
    Paddy i have a 28mm dellorto carb from a full power Aprillia rs125 on my wre and it absolutely flies!
    gazmcfaza likes this.
  7. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Cheers cooper. Can you give me some more info on your jetting and what ither mods youve done.
    Cheers
  8. SHY UK Husqvarna
    yes please
    Considering the price of the derestrict jetting parts, a carb' swapout seems like a very viable suggestion - if you're willing to premix...
  9. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Yeah shy its looking a good option. Can't make my mind up about the auto lube, not that its had to chuck a bit of oil in when i fill up.
    Could do with hearing from a few more people who have fitted the kit to find out what its like.
    Also looking for any other mod ideas.... Missed out on a top end kit on e-bay i was going to bore out. Oh well.
    Paddy
  10. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    what jets are in it? i had an 09 rs as well but it ran like crap compared to the husky, even with derestrictions
  11. cooper Husqvarna
    Kent UK
    wre125
    No idea what jets are in it. its a little boggy at low revs but after that its fine, the carb is from an 04 plate bike
  12. George234 Husqvarna
    UK
    Wre125 1999 spec
    kx250
    you gotta swap out the inlet manifold if your upgrading to bigger carb, i just done it myself to mikuni 38. big improvement!
  13. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Hi George, what manifold did you fit? Also how is yours jetted and what pipe are you using?
    Cheers
  14. George234 Husqvarna
    UK
    Wre125 1999 spec
    kx250
    cr/wr manifold, standard wr settings bud. Got a dep exhaust system on order. My bikes in bits atm. I got a fella from a company my company does work for to look to add an oil injection point to the carb so can ave it auto lube. Hes gerrin back to me about it
  15. paddy.t Husqvarna
    WRE 125
    Yamaha WR200
    Thanks George, any particular years of cr/wr wont fit?
    Im not fussed about looseing auto lube, going to shift oil tank and fabricate a tray insert to hold battery and some tools.
    Cheers.
  16. George234 Husqvarna
    UK
    Wre125 1999 spec
    kx250
    i just made sure it was specific to the year of my bike and trusted the dealer on the exact size. The wr/wre/cr can share parts pretty easily as ive found out by buying other parts of each of them for my wre
  17. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    what parts did you put on your wre george? Mine is standard and is fast enough but I know there's more power to come out of the engine, especially as the top end is just run in now
  18. George234 Husqvarna
    UK
    Wre125 1999 spec
    kx250
    It wasnt tha mine wasnt fast enough it just wasnt responsive as my previous bikes. As it stands now engine wise its got a race piston on top end. Mikuni 38mm carb and will ave a dep exhaust system on it. Im debating switching the flywheel ignition stator the cdi atm but i havent got the time as work feels 24/7
