Can anyone tell me how to do a leak down test?
Discussion in 'Vintage/Left Kickers' started by Grunbay, Aug 9, 2013.
  1. Grunbay Husqvarna
    Southern Maine USA
    1974 WR450
    OSSA, Penton, Ducati, Matchless
    I have a 1987 CR430 that may be needing new seals. I have a nice Snap-on leakdown tester that I got cheap on ebay, but I don't know how to properly use it. Also, it seems that I could easily blow out good seals by using too much pressure!
    Any experienced mechanics out there able to run me through this process?
  2. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    On a 2 stroke its not a blow by test.
    Its a vacuum test, plug exhaust and intake and see if it hold 6 or so inches of vacuum.
    When it wont maintain some neg pressure, the crank seals are needed
  3. RTM Husqvarna
    Cornwall England
    1983 CR250 & 1988 WR250
    Honda CRF450R, Cagiva WMX250, KX500
    pour paraffin into the inlet manifold. if it leaks u need new seals.
  4. Ron Husqvarna
    Azusa, CA
    I've always used pressure as a leak down test. Rule of thumb I was taught years ago is:
    pump it up to 6 psi, should not drop more than 1 psi in six minutes.
    I use an expansion plug in the exhaust, then made a plug with a gauge port and a schrader valve, in the intake manifold.
  5. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Hey, um Ron. The other day after you clocked out from work. The boiler in the basement of the building, stopped working. Boiler guy said the pressure gauge, some pipe and the blow off plug were missing? Ha, nice set up!
  6. Ron Husqvarna
    Azusa, CA
    I know nothing!!
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Sgt Schultz strikes again:D
