125-200cc can i bin the battery?
Discussion in '2 Stroke' started by richgilb, Nov 19, 2014.
  1. richgilb Husqvarna
    Hull, England
    WR165,
    Ducati SS 1100 Evo , Honda VFR 400
    Going to,view a 2001 wr125. Seller says bike does not charge battery. My thoughts are so what, who needs it anyway. My other bike does not use a battery. Does this bike need a battery?
  2. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Bike sound like its WRE not a WR if it has a battery !!! Pretty sure even the 2001 WR was never fitted with a battery unless fitted by the owner.
    Two very bikes, If fitted with cable operated power valves - none adjustable suspension ect ect its a WRE.
  3. richgilb Husqvarna
    Hull, England
    WR165,
    Yes it is a wre, where can I get spec differences?
  4. Al H Husqvarna
    Australia
    WR250 2001
    BMW R1150GS 2001, KTM620
  5. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    I have the wre, differences, wre has a 28mm dellorto carb, with an auto lube pump and oil tank under the seat/ oil pump on side of engine operated by throttle cable, radiator hoses are slightly different, have an extra piece connecting them on wre, blieve ignition timing is different so it's not as quick to rev as wr/ cr, and yes wre has battery under the seat, not sure if wr does/ should. Same engine though, I have cr head on mine
  6. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    and wr has 36/ 38 mm mikuni carb with premixed oil
  7. richgilb Husqvarna
    Hull, England
    WR165,
    Cheers, we got it for 600 quid in the end with v5. Needs work though......
  8. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    that's an allright price, what needs to be done? does it run?
  9. richgilb Husqvarna
    Hull, England
    WR165,
    Fork seals, wheel bearings, no charge on the battery.... so far....
  10. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
    the battery is for the power valve motor...
