125-200cc Can I run 2011-2013 144 kit on 2007?
Discussion in '2 Stroke' started by txmxer, Jun 20, 2014.
  1. txmxer Husqvarna
    future cr 125
    Yz 250, Drz 110, etc
    I tried searching can someone help me out on whether I can run the 144 kit from a 2011-2013 125 on my 07?? I want to say the motor hasnt changed that much right?
  2. Motosportz CH Sponsor
    yes you can
  3. txmxer Husqvarna
    future cr 125
    Thank You!!
  4. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I think you need the updated power valves to go with the new cylinder. The older ones were squareish, the new ones are oval shaped if I remember correctly.
    I don't remember when that change was though.
    Later,
    Motosportz likes this.
  5. txmxer Husqvarna
    future cr 125
    I think mines oval shaped, I just picked up about 7 used cylinders mostly 125 and a bunch of used fmf pipes as a parts package, Ill be keeping most of it but parting with some of it
  6. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    03 KX100, 06 KX85, 01 PW80
    You happen to get a gnarly pipe that would fit an 04 cr125? I'm putting a2012 144 on my 04. Let me know how yours goes if you get yours done first.thanks
  7. txmxer Husqvarna
    future cr 125
    Will do, it looks to me like there shouldnt be any issues. I didnt get a gnarly just some fmf powercore 2 silencers
  8. jimmyjamez12 Husqvarna
    pittsburgh pa
    04 cr125
    Ok cool thanks
  9. txmxer Husqvarna
    future cr 125
    How can I tell the difference between a 125 and 144 head? Are the heads very different on the 144s or not?
  10. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    Edge of the squish band will measure 58mm diameter, 125 will measure 54mm. A 125 head can easily be machined out to 58mm.
  11. txmxer Husqvarna
    future cr 125
    Perfect thank you!
