Can i use 10w/40 4T fully synthetic in my 2009 TE250
Discussion in '4 Stroke' started by gtvlew, Dec 3, 2013.
  1. gtvlew Husqvarna
    2009 TE250
    Hello everyone first post on here, my names Gary , ive just bought a 2009 TE250 and am wanting to do an oil / filter change , the manual states 10w/60 , will using 10w/40 shell advance 4T fully synthetic cause any problems , I can get the 10w/40 for £25 for 4 litres, the 10w/60 is around £49
    once again hello and thenk you in advance for your replies:)
  2. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    I've run synthetic 20w50, 10w40, 0w40 and a mixture of 20w50 and 0w40 in my 450, I have almost 17,000 miles on it.
  3. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Yes you can run 0W40, 5W40 or 10W40 and your engine bearings will actually run a little cooler. Look around for Shell Helix if it is available, usually in 5W40. (0W40 is the preferred grade currently at our shop).
    JonXX likes this.
  4. ghte Husqvarna
    Bright, Victoria Australia
    Go for it. A semi syn is also fine for trail riding
  5. gtvlew Husqvarna
    2009 TE250
    thank you lads
  6. bud7041 Husqvarna
    te250
    Been going to change from Motul to Castrol engine oil as Motul is a bit hard to get in the town were I live. Know that in the manual for te250 2011 they recommend 10w50 Castrol but can not buy in Australia so told not imported for some reason unknown. So does anyone use a Castrol that they recommend.
  7. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Use 0W40.
  8. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    I use Rotella T6 Full Synthetic 5W40 in my KLR. Shifting is butter smooth. Better than the Mobile 1 Synthetic Motorcycle Specific Oil. A lot of KLR guys swear by it. And it's cheap. In my TE511 I'm using the Mobile 1 European Car Formula 0W40 mentioned above. Seems pretty good.
  9. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    I've been running Amsoil 10w40 motorcycle oil in my 07 SM610 for the last 50,000 of it's 54,000 miles. I'm running Amsoil Powersport 0w40 in my 10 TXC250.
    Mike-AK likes this.
  10. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    I have used Motul Full Synth 10w40 on my 310, our motors are identical apart from ~50mm bore. I have foud the oil to be excellent.
  11. bud7041 Husqvarna
    te250
    Got Penrite 5w-40 full synthetic in shed been using it in the young sons quad don't know weather to give it a go or not. Does anyone use Penrite oils in there bikes.
    Tinken likes this.
  12. bud7041 Husqvarna
    te250
    Changed to Penrite 5w-40 hope will be ok. Thanks Tinken for the confidence to try it mate, still a bit concerned about the change?
    Tinken likes this.
  13. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I like Penrite 5W40, they have some new versions out too like enviro and everyday plus. The enviro is very similar to M1.
    bud7041 likes this.
