125-200cc Can't stop fuel from coming out float overflow
Discussion in '2 Stroke' started by bsh7680, Jul 14, 2013.
  1. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    04 PW 50, 08 KTM 50 JR Pro
    I have a 2012 cr 144 and gas started leaking out of the overflow a couple of rides ago. I have had my carb apart about 10 times to clean it and adjust the float. I had it stopped before my last ride and it started leaking as soon as I turned the gas on. The carb is stock and had not had any problems. Any suggestions.
  2. James Patton Husqvarna
    Edwardsville, ILL
    TE511 2012, WR125 2006
    1250S Bandit, DRZ400S
    Only 3 things can cause it to overflow. 1. Float level to high. 2. Foreign matter trickling thru not allowing needle
    to seal. 3. Needle and/or seat bad.
  3. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    Don't forget too look for hair line crack in brass over flow tube. That has gotten me before. Fill carb bottom when not on carb and let sit for a min.
    James Patton likes this.
  4. ajaxauto Husqvarna
    Check the o ring rubber that is around the outside of the seat needle and seat might be good but the seal around the seat could be bad
    ray_ray likes this.
  5. bsh7680 Husqvarna
    Cookeville TN
    12 CR 150
    I am going to check the overflow tube. I have another carb off of an 09 WR 300 that i have and it did not leak. I changed the float assembly including seat and it still is leaking.
  6. ajaxauto Husqvarna
    Pull the brass seat assy and check the o rong around the outside of the brass seat not the inside part where the needle goes
    ray_ray likes this.
  7. mkfox Husqvarna
    Michigan
    2002 WR250
    1973 Greeves Griffon
    I have been having the same problem. Had the carb apart 3 times. Adjusted float level, cleaned, inspected everything. Everything seems fine. Then mysteriously appears again (last night). The next time the carb comes out, it will be collecting dust on a shelf. It's now time to have Kelly resolve the situation this week. :D
    sabortooth likes this.
  8. dfeckel Husqvarna
    Medford, NJ
    I had this same problem when my '13 was new. I didn't want to chase it for ever, so I just bought a new needle, seat and o-ring. It's been fine for the last 30 hours.
  9. ray_ray Mini-Sponsor
    The Philippines
    This 0-ring was the issue on a couple of my bikes also ...
  10. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    a float that won't will do it ever time but thats pretty rare are you bending the little tab that pushes the needle up
  11. Caferacerman Husqvarna
    Where did you buy the needle, seat, and o-ring?
