Cant Tell What Bike I Have.
Discussion in 'Vintage/Left Kickers' started by taticalguru, Aug 1, 2011.
  1. taticalguru Husqvarna
    New Hampshire
    Hello im new to dirt bikes a got from a friend a bike i was told it is a 1985 cr250 the frame numbers are hard to see do to the paint. It has A mono shock, liquid cooled, rear drum and front disk. dose this sound about right. The other Thing is the rear drum bake support bar mounts to the frame should there be a barring on the frame end of the bar?
    Thanks for the help.
  2. mattmcphail Husqvarna
    Jacksonville, FL
    Do you have any pics? That would be a huge help.
  3. photoguy_43420 Husqvarna
    Ohio
    11 Husqvarna's from 1973-2001
    73 Norton Commando 850
    It sounds like it could be a 86. There should be a bearing in the frame that holds the brake arm.
  4. taticalguru Husqvarna
    New Hampshire
    ok the bikes at work I will get some pics up tomorrow. Can you help me with the part number for the bearing?
  5. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Sounds right, here's 85 CR brochure, it's a 500CR , but the 250 looks real close. There's 2 bearings in the brake arm lever (73 82 198-04) & 2 where it mounts to the frame ( 73 82 302-34)
  6. taticalguru Husqvarna
    New Hampshire
  7. ruwfo Administrator
    NJ
    Yes those are the Husky Part no. for the bearings, i think the lower chain roller bearings are the same.
  8. taticalguru Husqvarna
    New Hampshire
    ok ill look into it if not i can mic out the boss and get some. BTW http://www.applied.com/ is the best place to get bearings and other industrial supplies. If you dont have a part number you can give them the dimensions and they will fined one that fits. example swing arm bearings P/N: HK2216 in stock $3.00 locale pick up http://www.husqvarna-parts.com $28.00 plus shipping. Now dont get me wrong i'm not putting down http://www.husqvarna-parts.com but that's a bit on the pricey end of things and the ones from Applied are high end made in England Timken's.
  9. taticalguru Husqvarna
    New Hampshire
    Found the part number for the 73-82-302-34 its 626-2RS
