Hi Guys , just upgraded my son from a Yami ttr 50 to a Yami ttr90, I know I know its not a Husky, but I need Husky input! The Bike is mint and was my buddies Sons BIke which he out grew and the bike has been sitting , needless to say to carb was like jelly and the gas was bad ,real bad! I took the whole carb apart and cleaned it, when I put it back together she fired right up, when I drove it, it, the rpm continue to rise after you strop throttling the bike, so with the throttle closed position the bike will still want to roll out. Still dirty? I took it apart and I am soaking jets over night, I had a total clog in the pilot jet so I found a microscopic drill bit and ran it through there and it opened up the clog. Ok guys fire away! Thx for the help!
risky putting metal inside a jet as the size can be changed very easily and a small fourstroke has to have a tiny tiny pilot. it may be best to install a new clean pilot. are you sure the throttle is closing completely and the cable(s) are free? any air leaks between carb and motor? did you remove the tank, clean the petcock, and flush it out really well with fresh gas?
I agree and those things have been coming to mind, I actually am going to buy new jets to see if it makes a difference, they are cheap enough. the for the input
