125-200cc Cause of bad clutch drag? wr125
Discussion in '2 Stroke' started by Yellowfin, Sep 1, 2015.
  1. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Mike bike sat for about a month as I was busy at work. Now that I have been able to ride my clutch is dragging really bad.
    I have to give it throttle when I am stopped to keep clutch from stalling engine>
    Any ideas? I tried to adjust it at the lever and its all the way out and still dragging.
    Thanks in adavnced
  2. ray_ray Mini-Sponsor
    The Philippines
    If the clutch was working OK before you parked it, I can't see anything but the oil or plates being sticking together causing the issue... Simple attempt 1 change the oil ... Next go inside the clutch and clean the plates and fibers ... You can always sling $ at it and purchase something new.
    Recently I had to work on a 3rd party clutching device on my bike and tore into a clutch for the first time ... If you have any mechanical skills, the work is pretty easy...So easy, I might go inside a standard clutch on my WR250 and see if the plates are dirty or the plates have notches cut on their top tabs that might need shaving off....
    There are many here who have lots more experience on the subject matter than myself, so more clues should be on the way ...
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    1. Cable stretching or 2. warped clutch plates is the most common causes... in that order.
  4. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    first check the oil level
    if problem not found
    2nd check operation and adjustment of cable
    3rd remove clutch cover and clean and check plates
    find beer
  5. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    As the aboves but beer first lol.
    Had a bike do that once and although every thing looked good it was a broken friction plate, Couldnt see it upon inspection but on the second strip down I twisted the plates in my hands and low and behold one was broken, Not saying that is the problem but if the basket isnt grooved badly it maybe .
    My huskys prefer ATF in the tranny/clutch and even start in gear easily compaired to the other types of oil I have tried.
    Miezie666 and ray_ray like this.
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    I find that the first thing to go when oils due a change is my ability to select neutral.
    Drain oil check plates, could of had the clutch over tensioned in the first place and streached the cable, wasnt resting on a wall with clutch in for a month?
    ohmygewd likes this.
  7. ray_ray Mini-Sponsor
    The Philippines
    Laying the plates on a piece of glass can help identify if a plate is warped or not ...
    2premo and ohmygewd like this.
  8. WVdag Husqvarna
    Smithville, West Virginia
    2007 WR250 W/300 kit, 2013 CR125
    1987 Harley FXLR 10th year edition
    I ran out of adjustment on my 13 CR. I used an old aluminum cable adjuster thingey, by old I mean "70's" honda or yamaha,and slid it over the end of the clutch cable at the engine. I tried to send a picture from iPhone not sure it worked. Picture I mean. The other worked great.
  9. Yellowfin Husqvarna
    Ocean City, NJ
    '13 WR144
    kdx220 (sold)
    Thanks guys Im gonna run it out this weekend to see if I cant loosed it up.
