125-200cc Chain roller sizes
Discussion in '2 Stroke' started by shawbagga, Dec 10, 2015.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    32, 36 or 42mm? What size is stock? Better to go for biggest to allow for wear? I chucked one out as the bearing literally fell apart when I went to regrease. In hindsight should have just bought a new bearing(hadn't worn much) but didn't realise could replace em
  2. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Which bike mate. If it's the 165 I can measure the corresponding roller on mine.
    I'd recommend staying with the original size......something to do with chain tension at the extremes of suspension travel.
    shawbagga likes this.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    On my 300 it's 32mm. Thanks for reminding me to check mine again soon :cheers:
  4. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Which roller Shawry?
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Top n bottom the same n same on 300 n 165. The bearings shit emselves so best to regrease em every 6 months or so takes 5 min. I have to keep swapping between bikes depending on which one I wanna ride n it's gettin annoying
    steadydirt likes this.
  6. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    If you have the time and patience; you might look at the bearings for roller blades at the sports store. Sometimes you can buy the right bearing pack to repair 1 set of rollerblades OR use the bearings in your chain roller and have 8 or 10 spare sets.
    ohmygewd likes this.
  7. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    The bearings for the chain rollers on my 250 are 6801 which should be the same as all the stock rollers.
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    So oem dimensions are 32mm diameter n 28mm width with an m8 bolt correct? Sorry forgot to measure whilst at home n now back at work. I'm looking at some Chinese ones on fleabay(yes I'm cheap) which are 35mm diameter n 26mm width. Surely coupla mm make bugger all diff?!
    There's also some flash red ones that are recessed in the middle so prob only 20mm thick where chain will contact it. Likely to affect anything?
    Wouldn't mind the red as I wanna get the TM design works red slider n guide so red to match but the red TM rollers are like $60aus so hard to justify for chain rollers when I'm not sure they do much(not as much as the slider m guide anyway!). Plus I need four for 2 bikes so really exy! Thoughts people?
  9. Oldscool Husqvarna
    South Australia
    None
    Go for it mate. Get the red ones. So long as they keep the chain from eating the intake boot and anything else nearby you should be fine. Just make sure the recess in them is wide enough that it doesn't bind on the chain and that it doesn't try to miss align the chain with the front sprocket.
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I just put some new red ones on the 144, 34x28mm, cheap and get in a minor bind when tightened. Still work fine though. TM Designs just OK, overpriced IMO. I'll get BRP next time.
    :cheers:
  11. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    We happen to use Delrin at work, so I use leftover pieces to make my own. For the bottom ones I use a bearing, but the top ones, I just drill an 8 mm hole, as the roller only makes incidental contact, and IMO, a bearing is overkill, complicated, expensive, and heavier.
    NCSteve and Oldscool like this.
  12. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    What brand/sort(recessed type?)/price Steve? Ebay specials?
  13. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yes the recess thing concerns me a little when susp fully compressed. Worried if not aligned may cause chain torque/twist like you say Oldscool. Cheap enough to try I guess. We have poly pipe(black) at work that can make some out of plus white nylon could do same but really want red! Can't find any non recessed red type on fleabay?!
  14. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I got mine off amazon when looking for other stuff. They don't have any recess. :cheers:
    http://amzn.com/B019404JGW/
  15. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
  16. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Geezus! this site is buggy tonite. I got the kit with 2 for 14.50us :cheers:
  17. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeh saw those I'll check what shoppin to Aus is worth. Cheers
  18. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Bam found some for $25us delivered! 4 of em too! Normal type not recessed & run a bearing(coming from china guarĂ nteed high quality haha). They're only 30mm diameter but have the 'powerlip'(TM design works rip off) which is 4mm more OD. 30mm long so slightly longer. Found em under 'red chain roller' on ebay. Mx pitbike the store name. Goes to show simplest description often the best with fleabay!
  19. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    One more question there's a red slider on ebay that fits late 90s-02 model 125/250/360s. I'm fairly sure it's the same swingarm on the newer 300s hence same slider yeah? TM design works don't do one it seems n rest are black. Cheers yall
