Changing shock oil
Discussion in '4 Stroke' started by ghte, Dec 7, 2009.
  1. ghte Husqvarna
    Bright, Victoria Australia
    Guys, is this something you can do at home or is it a shop job.
    If its a home job is their regassing involved. If its a home job how do you do it properly and what is the best shock oil to handle the heat.
    Cheers.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    It's more of a shop job than a home shop job. You will need the right tools, need to know how to properly handle, depressurize and disassemble the shock, reset the reservior piston if it doesn't have a bladder, properly bleed all the air out of the system and you will need a special bleeder and nitrogen to ensure proper re-pressurization. You could probably do it all and then have a shop put in the nitrogen. I have rebuilt and revalved Kayaba shocks and I rebuilt the WP that blew its brains out on my KTM, but I haven't tackled the Sachs on my TE yet. I have enough bikes that need that sort of maintainance that I keep a nitrogen tank and T-bleeder gauge on hand. I just use Honda brand shock oil in all of my bikes.
