dfeckel;70854 said:Big, black Sharpie.![]()
Motosportz;70896 said:First ride on my new TXC and got a branch in the front wheel and stripped the rim all the way around. Made changing tires EZer.![]()
Much better idea.... That would be ideal compared to what I have used. ThanksHuskyDude;70933 said:All my rims are black on my bikes so I find myself changing tires a lot. I cut 2" length of 3/4" Plastic pipe (Pex tubing) then slice the pieces from one end to the other. Every time you need to move your tire iron just use another piece of pipe.
Only bad thing is they don't have a rope attached to them and you must be careful they don't go inside your tire. A good tip is to count how many you start with...don't ask me how I found that out.![]()
PC.;70964 said:Follower
Happened to me at D Mill back in May. I was not happy.
First black rims ever and the rear gets lathed by a alder branch the 3rd or 4th ride. For real!?!?!?![]()
