250-500cc Changing WR 300 oil
Discussion in '2 Stroke' started by PJBlank916, Oct 19, 2015.
  1. PJBlank916 Husqvarna
    TE 300 (soon)
    2013 Crf 450r KDX 200 CRF 450X
    Hi I have a 2009 WR 300 and am changing oil for the first time how much gear oil do I put in it ?
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    It has a sight glass, fill it to around 1/2 way to 3/4....make sure you lean the bike side to side before letting it settle to get a correct reading.
    As an indication, when you have a hard time finding neutral, time to change the oil....or every 3-5th ride, all depends on how you ride.
    Hope it helps.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    rtfm! should be @ 800ml. You can measure how much comes out, use the oil check screw to confirm @ correct amount.
    :cheers:
  4. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Steve's right. No sight glass on the 2009. There's a screw you take out. On my 250 800 ml is always spot on.
    Borntoride71 likes this.
  5. ohmygewd Husqvarna
    Aprilia RSV1000
    Sorry guys, never knew the 2009 had no sight glass..wonder if clutch covers from previous models with sight glasses would fit?
  6. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    My 2012 doesn't have a sight glass until I install the 7602 cover :thumbsup: I see them on 125s though, not sure if the CRs have them :confused:
    Colo moto and shawbagga like this.
  7. ohmygewd Husqvarna
    Aprilia RSV1000
    Earlier models don't fit NCSteve?
  8. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Good question mate. I went for some 7602 bling, but would be good to know. :cheers:
  9. lankydoug Husqvarna
    MO
    WR
    TM 300en
    An 09 has a screw on the cover that you can remove for a level check. The correct amount is 795cc, I find measuring it is much better than using the level hole plus the small screws in thin covers have a tendency to strip out.
    shawbagga, 454x and NCSteve like this.
  10. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    Or 27.5 oz. for dummies here in the US
  11. Jhunter Husqvarna
    Atlanta
    I've been putting 750 ml (23.5oz) in my 2008 WR250. I better go back and check to make sure in doesn't call for more...
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    WR 250 calls for .7 imp quart which converts to .84 US quarts. .84 quart = 26.88 ounces or 794.936 ml.
  13. Jhunter Husqvarna
    Atlanta
    Thanks Noobee. I'll make the adjustment (2oz +/- is within my comfort zone). :thumbsup:
  14. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    You're welcome, I was all over the conversions because I just changed the oil today myself. We have perfect riding weather right now. Gonna ride a top secret HnH practice loop tomorrow.
  15. burstcasino Husqvarna
    Austin, TX
    2012 Husqvarna WR300
    2001 KTM 520 exc
    My manual says 0.8 litres or 800 ml. Checked it once with the screw and it seemed spot on. Just put in new tranny oil after the last ride and my fluid was too silver-grey for my liking. I guess I've been abusing it too much.
  16. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    How many hours btwn oil changes?
    I just did an oil change and installed 7602 clutch cover with sight glass. 800 cc/ml fills it just to the top of the sight glass :thumbsup:
    burstcasino likes this.
  17. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    I only ever run it half way in sight glass(cold engine). Wouldn't be much difference I spose never really checked amount but spose be around 700-750ml as never get it all out of cases when changing
  18. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    I got mine warm and drained yesterday. I added a tick under 800 ml because I have no easy way to measure small cc/ml amounts. It worked fine today and there were some nasty rocky climbs.
