Chassis Oil Filter
Discussion in 'TR650' started by DerBrizon, Jan 16, 2015.
  1. DerBrizon Husqvarna
    2005 Suzuki SV650S
    What the heck is this!?
    In the service manual it says ever 20k KM to check/clean "Oil filter (on oil return pipe from chassis)."
    Anyone know anything about this?
  2. hasenpfeffer Husqvarna
    CO
    Is this talking about the screen in the fitting that goes into the frame oil reservoir? I haven't seen anyone look at it, except 1 guy that found the entire fitting loose from the factory.
  3. DerBrizon Husqvarna
    2005 Suzuki SV650S
    That would make sense. Which hose/where is the screen? I've done two valve inspections and one adjustment so far and have not encountered it even when removing the oil tubes that connect the motor to the chassis resevoir, at least as far as I can recall.
  4. hasenpfeffer Husqvarna
    CO
    One of those tubes attaches to a fitting on the frame which can be unscrewed.
  5. hasenpfeffer Husqvarna
    CO
    #8 of drawing 24, page 60 of the tr parts catalog.
    DerBrizon and engineerk9 like this.
  6. Riding Again Husqvarna
    Palm Coast, FL.
    2012 TE511
    Sold TriumphTiger800xcx, TR650 Terra
    Just looked this up and curious if it needs to be replaced or cleaned. It is $12.20 from ktm parts if any one is interested.
  7. glitch_oz Husqvarna
    AUS
    Strada
    Looks like one of those basket-sieve type filters, washable.
  8. engineerk9 Husqvarna
    Narrabeen
    Terra 650
    Kawasaki ZRX1100
    I'll pull mine out tomorrow to check, well spotted Hasenpfeffer
  9. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    Its a screened cage on the back of the fitting to catch the supper chunk....My was seeping...I replaced it with a steel fitting and locktited it into the frame. I am also replacing the snail clamps with crush type band clamps on all oil lines.......if it can go wrong it will....a quote by Murphey
  10. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    Mine was weeping so I replaced the "o"ring with a viton one from my Aldi set.
