Check out this bike with frame issues!
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by krieg, Jul 10, 2011.
  1. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
  2. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    450 SMR, TE250, CR125, SM610
    Duc, Buell, Honda
    Lower triple/steering stem came apart. Ouch, that must have hurt!
  3. knobbytired Husqvarna
    Should that say 'aren't' ??:)
    There was a vid of a Kawi KX out there somewhere with a similar issue, except it broke the steering head right off the frame...ouch!
  4. Coffee CH Owner
    I believe so. I've seen a few of those videos from other brands.
    Before I change the title, has there been some similar breakage in a Husqvarna? I've not seen any... Yes I am aware of other occasional things like muffler tabs being weak, but not what is shown in the video.
  5. BadMotoWeazal Husqvarna
    Alabama
    KTM had a little test ride at Mill Creek MX a year or 2 ago. Frame broke at steering head, rider hurt. *%it happens.
  6. Coffee CH Owner
    It sure does...
    I will forget about this thread if I don't do something...
    Original title:
    "Irrefutible proof that Huskies are the ONLY bikes that have frame issues !"
    Lets try this title (again I've not seen any major frame issues at all on a Husqvarna)
    "Check out this bike with frame issues!"
  7. krieg Husqvarna
    Matthews, NC
    Many in the past
  8. Coffee CH Owner
    Definitely missed that thread...
  9. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    some frame issues i've had:
    '03 cr250r: cracked at head
    '04 cr250r: cracked at head, cracked spars
    '00 klx300: never stopped cracking and breaking all over the place
    '89 kx125: shock mount, snapped off
    '88 or '87 rm125: lower cradle snapped at weld
    list goes on...
    stuff breaks....inspect your frames and hard points on a regular basis. like every time you go to use it.
    the neck ya save may be yer own.
  10. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    a quick addition, torque all your hardware to factory (SAE or other) specs. At a glance he has the other crack on LH lower, who knows what "they" did to the triple prior to catastrophic failure (over or under torque).
  11. Motosportz CH Sponsor
    Thats about the 6th KTM clamp I have seen snap there. They just had a recall on bar mounts snapping as well. Lightness is not free. That said all bikes have issues.
  12. pvduke Husqvarna
    ... on the gas...
    99% of clamp failures ive seen are caused by gorilla-wrench.
    i have a man locally that welds them, yes, welds them. seen a lot of clamps saved that way!
    BadMotoWeazal likes this.
  13. jlk_250 Husqvarna
    Minneapolis, MN
  14. BadMotoWeazal Husqvarna
    Alabama
    Don't think I could ride with confidence if the triples were welded. I know the weld is usually stronger that the material being welded, but still it would be in the back of my mind.
