Biggziff
So my super clean 09 510 was apparently kept super clean with a pressure washer. I pulled the rear tire to rotate the tube (it had slipped) and maybe install a second bead lock and didn't like what I found. I'm assuming the spacers are toast. I'm already going to order new bearings and seals, but the question is which bearings to get (All Balls?) and where to get spacers that aren't so soft?
Also, any tips on driving the bearings out or using a puller?
Here's a few pics. The drive side actually looks pretty good and the bearing feels fine, but I'm pulling everything to be sure. I'll end up doing the fronts and the suspension bearings as well as I can't trust that they aren't full of water and dirt also.
Brake side...ugly
Spacer with extra grooves...
Another extra groovy spacer
Axle isn't too bad. It had zero grease on it.
Brake side...ugly
