Checking fork sag?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by uranys, Mar 18, 2013.
  1. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    Can anyone point me to or write up the best way to check fork sag? I've been doing it the same way I would do the shock, but stiction gives me some pretty big variances.
    Should I be warming the suspension up before doing this?
  2. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    I don't check sag much on my forks because of this same issue. But when I did I always bounced several times before measuring.
  3. gillies Husqvarna
    Phoenix, AZ
    '11 TE449
    '09 R1200GSA
    Put all your gear on. Mount the bike and stand on pegs in riding position. Have a helper push down on bars to compress forks and release. Measure. Have helper pull up on bars to extend forks and release. Measure. Split distance between measurements and get your sag. Paraphrased from Race Tech Suspension Bible.
