Chinese Zox quad need carb help
Discussion in 'General (Main)' started by HuskyT, Oct 18, 2009.
  1. HuskyT Moderator
    Corona, California
    Subject: Chinese zox quad renegade 110
    Will only run on full choke. Flip choke off motor dies.
    Pulled carb/disassembled .. air filter had a lot of crud impacting airflow.
    Found small jet (idle???) to have a very slight bend in the tip??? installed this way at factory???. Jets have no numbers on them. can't find any marking on them whatsoever. Holes are clear and unobstructed.
    How do I know what brand of Carb this is? How do I determine the actual jet size. Do I buy a new carb for about $30 or try and find jets for this one.
    The screw on the right is my idle adjustment?This is the idle jet correct?
    What is the screw on the left and the screw on the right and proper settings... e.g. 1.5 turns out?????
    Source for jets and or a new carb..... ?
    Note: reassembled after cleaning everything and fresh airfilter screens... will still only run on full choke?????
    T
  2. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    T,
    I think the whole motor is a Honda clone use the Honda specs? or use the specs from those fast 50s- 110 Honda custom mini machines like from BBR or Powroll, the carb should be a Keihin clone like the type on the XR50 type motors, it is a fwd slant 4 stroke clone right?R
