Choke Adjustment
Discussion in 'EFI/carb' started by ozzie, Mar 26, 2016.
  1. ozzie Husqvarna
    Hey all I have a 2008 450 TE just would like to know can you adjust the choke on it and if so how??
    Cheers Kel
  2. craigy Husqvarna
    Sydney, Australia
    TE 450 08
    KTM 125EXC, Ossa SDR
    The 08 450 is Fuel Injected and doesn't have a choke just a fast idle knob. It is affected by the idle screw as well. If you screw in the idle you will notice the knob is pushed out. I'm not sure what you mean by adjust, as it is either in or out.
  3. ozzie Husqvarna
    Thanks Craigy, I thought that it was a choke, thanks for clearing that up for me
  4. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    It helps starting when cold when you pull the fast idle knob out. The engine turns over a lot longer without it. Set your idle speed to 2000-2200 RPM's with the Phillips head screw. Mine sometimes needs a small amount of throttle when cold. Push the fast idle knob in after 30 seconds or so. Hope this helps.
