choose exhaust cans...
Discussion in '610/630' started by Huskyvarna, Mar 12, 2014.
  1. Huskyvarna Husqvarna
    Husqvarna TE 630 2010
    Hi.
    I have searched for opinions about exhausts on TE 630. I have to say im getting a bit confused from all answers.
    Im going to keep the stock front parts, im only about to change cans.
    Im about to choose between: FMF Q4 single, Leo Vince duals, or the GPR furore duals.
    I dont want much more dB, all these seems to have a quiet insert.
    What do you think i should go for? Does the FMF single have much more noise than the duals?
    A benefit with the FMF would be that i can place a "tooltube" on the right side, where the can has been.
    Would be great with some opinions, Thanks in advance...
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    FMF has always been a crowd pleaser at voodoo conventions, guaranteed to wake the dead from extreme decibels.
  3. RDTCU Husqvarna
    '11 630SMS
    The FMF is definitely more brap-y, I prefer more of the deep mellow tone from gutted stock cans or something similar.
  4. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    My FMF Powercore 4 with quiet insert is actually quieter than the stock dual cans at idle and normal throtte. Only at very high rpm throttle twists does it braap louder than stock. In the install process I lost all the cat heat, dropped 14 lbs, gained a clean right side and quieter early morning startups thus pleasing my neighbors. I think the FMF can looks great also after removing those bright colored stickers.
    _
    Fast1 likes this.
  5. Huskyvarna Husqvarna
    Does anyone know if Q4 with the quiet insert has similar dB to the powercore 4 with quiet insert?
    I dont want the high braap at low rpm, and as youre describing SilverBullet, it sounds like a good setup... But i cant get the powercore for a reasonable price, only q4..
  6. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    Q4 is quieter bud. I had powercore 4 with q4 insert in it and it was okay. Still quite loud. Fell out on the freeway and the seat of the pants dyno told me to never go back! Been running loud as hell for a few weeks now ;)
  7. EricV Husqvarna
    Does the insert shave a little from the seat of the pants dyno? I've got the Powercore 4 and have been putting off adding the quiet insert. If it does restrict power I probably won't get one.
  8. huskylove Husqvarna
    norcal
    It definitely does, even with the power commander and auto tune so its running "right" it does make a difference, the bike just does not rev as quickly.
    But I have a 511. So different animal.
  9. Huskyvarna Husqvarna
    Ok, but i know that i wont drive it without the quiet insert because its probably too loud without it.. im not searching for the maximum power.
    The main tought here is to get rid of the cat.. which are just causing trouble.. heat, powerloss and so on
    i dont want it to get much louder than the oem cans.
    The good thing about the leo vince and gpr is that they have the street approval here in Europe, i dont know how necessary it is but a good point.
  10. igun Husqvarna
    New York
    SMS 630
  11. RDTCU Husqvarna
    '11 630SMS
    To be safe, I would select the TE630, since the The SMR 630 is technically this:
    Though they are probably using SMS/SMR interchangeably.
    As for the company, never heard of them, but that is one funky can, with the wingnuts hanging out everywhere.
    "Universal Installation" usually means you're on your own for mounts and inlet plumbing.
  12. Huskyvarna Husqvarna
    well, now i have decided. I ordered the dual Leo Vince...
    They were cheapest also..
    I will post a picture when mounted.
  13. igun Husqvarna
    New York
    SMS 630
    Can anybody tell me how much hassle it is to convert to single exhaust? (as opposed to slipping on the 2 cans)
  14. mekanik Husqvarna
    Kootenays, Canada
    I converted to the Leo single, one of the best things I have done to the 630, simple enough to do. Nice sound and weight loss. Why run two when one will work?
  15. Huskyvarna Husqvarna
    I dont have any pictures yet, but now im running dual leo vince. Tried to run them without quiet inserts... But they got a bit too loud...
    They sound awesome even if i use the quiet insert and the best of it, you can feel a power gain. Many people has talked about weight loss when changing from stock pipes, these feels like they have the same weight as stock mufflers.
    The finish and quality looks very well on these, i can recommend them.
