Clarke tank on 07 TE450
Discussion in '4 Stroke' started by ScottyR, Jul 14, 2009.
  1. ScottyR Husqvarna
    Mitchell, ON
    Does anyone know if a fan works on an 07 TE450 (E3 spec) with the cooling fan?
  2. Coffee CH Owner
    Scotty I'm not sure what you are asking.
    If it is an 07 TE450 (E3 spec) that has a cooling fan - the fan should indeed work. Wetdog had one of those in Canada and other people had the E3 07 spec bikes.
    If you don't find what you are looking for I'd ask over at TT cause CH was started in 2008 - after most of the E3 spec bike discussions took place.
  3. Swampds Husqvarna
    Sarasota Florida
    I have a euro 450 with a Clarke. The fan is pretty tight with the tank but it does fit. I broke my fan because I didn't have rad braces and the rad pushed the fan into the tank. I am kind of concerned with the new braces (OFG). I have not replaced the fan yet but the brace locates the fan with more spacing from the radiator, but it looks to be a little lower also.
  4. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    You fan won't work as well with the OFG braces. That extra spacing seems to allow to much air, so it pulls less through the radiator.
    I picked up a set of MOTOSPORTZ braces so I can run the stock bracket.
  5. tallywacker Husqvarna
    SW Oregon
    Do you know what brand these braces are?
    They have the fan mounting holes already in them.
