TE/TC Cleaning air filters
Discussion in '2st' started by HS507, Feb 28, 2016.
  1. HS507 Husqvarna
    NE Ohio
    Te 300
    Yz450,crf150r,crf100f,crf50f
    I use purple degreaser and pinesol for a while now, both work great. Anyone use landry detergent? Just hit me as an idea in basement today.
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Good old kero to clean the the dirt and old filter oil in one bucket then in another bucket of warm soapy water with a bit of laundry powder to rinse, dry and then apply filter oil.
    justintendo likes this.
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    the misses will be way torqued off if you wash air filters in the washer just sayin i use gasoline for the first pass then fake dawn dish soap and hot water SWEEZE [NO TWISTING] as dry as possible then hang it up somewhere and air dry
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    gasoline outside for the win! let dry and reoil...done deal and doesnt hurt the filter at all. gets the filter clean fast! never tried it but i bet kero works too..
    i have a bucket i use with a cookie rack at the bottom to let the dirt collect below it..
    Trenchcoat85 and ohmygewd like this.
  5. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    If you use belray it takes a blow torch to get that stuff off..... so I use gas
  6. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
  7. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    I just use simple green and hot water. Pour it down the sink when done. Let the filter air dry and re-oil.
  8. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    i was a soap n water guy [for safety] thought i was gettin it done them one time i found myself outa soap so i used gas DAMN was i wrong good filter oil is tuff stuff i always two step it now BTW if you need your filter dry quick and dont have an air compressor after you squeeze out all you can wet it down with alcohol work it in good so it mixes with the water give it a squeeze the alcohol evaporates real quick and takes the water with it
  9. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    Bel-ray tip: cut it with white gas (naphtha, coleman fuel, lighter fluid: samey-same in the US) about 4:1 before applying it to the filter, and the filter oil will now spread super easy and fast. Evaporates in about 5mins.
    I imagine gasoline would work too- it's just not as volatile. ...and would drive the saftey nazis even crazier.
    sidebar: my dad, who had the most laissez-faire attitude about gasoline of anyone I know, spent a year in the hospital during the Korean War after suffering major burns from a gasoline fire while in the Navy, in Manila bay. That shit scares me though- and naphtha is worse ('cept maybe not so toxic). be careful
    juicypips likes this.
  10. justintendo klotz super techniplate junkie
    yup, i always use bel ray. it stays put! no drying out if the bike sits a bit
  11. Husky-Nut Husqvarna
    Connecticut
    1983 WR250, 2020 FE501
    1931 Indian 101 Scout, 1936 Chief
    Which do you prefer: Dip the filter in a tub of oil and squeeze out the excess, or the spray on aerosol type from a can? :confused:
    I have done both, and tend to prefer the spray on type.
    When I dipped the filter in oil and squeezed out the excess, the filter always seemed to have too much oil in it. (read: dripped from the air box for a day or two) :o
    ride200mi likes this.
  12. HS507 Husqvarna
    NE Ohio
    Te 300
    I never go excessive on oil (saturate by dunking) because i clean every race or ride. I put quarter size amount on nitrile glove and only kneed outside of filter (3times) and if it has a sticky draw between 2 fingers in several spots on outside of filter? Im done. Clean with pinesol of degreaser. Moving to dawn dish next
  13. HS507 Husqvarna
    NE Ohio
    Te 300
    But i ride dirt and mud not sand
  14. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    No Toil all the way for me these days, except I use Oxyclean and hot water. No gas or other toxic chemicals needed or put down the drain! Much cheaper overall too.
    Twin Air filters with No Toil work great, no sign of dirt beyond the filter. Cleans up easy and a spoonful or so oil spreads easy, hang the filter overnight, squeeze again with paper towels and ready to go. I've got 6 filters now and PC filter skins too, so always a clean 1 waiting.
    :cheers:
    310huskyTE likes this.
  15. HS507 Husqvarna
    NE Ohio
    Te 300
    Yes i agree need more than one filter AND BIKE haha
  16. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    I put my filter in a plastic shopping bag. Then I pour some filter oil into the bag and work it into the filter. Then I wrap the filter in a paper towel and squeeze out as much of the oil as possible.
    ohmygewd likes this.
  17. racemx904 Husqvarna
    owenton, ky
    dont dunk it in oil that is waaaay to much.... drizzle or put some in the palm of your hand and knead it in..... I do 3-4 at a time and store in seperate zip lock bags....
    No Toil is NO WHERE near as good as Belray..... PERIOD When it comes to letting crap into a $1000 engine I will take safe over sorry every time....
    Same with spray on.... its ok but thats about it.... I want sticky crap that dirt cant find its way thru.....
    johnnyboy likes this.
  18. JonXX Administrator
    Bill's Motorcycles Plus
    360CR 360WR SM610 TC450 TXC250 TC250
    Hondas, Harleys, Yammys & a squid
    Hot water and Dawn with a cookie rack in a 5 gallon bucket. I just slowly place the filter dirty side down on the cookie rack and let it sit there a minute, then swoosh it up and down a bit. It floats the dirty Bel-Ray right off and sends it to the bottom. Squeeze out and shake out, then put the filter in a gallon ziploc bag with some oil, squeeze it in and it's ready to go when I need a freshie.
    NCSteve likes this.
  19. 310huskyTE Husqvarna
    Melbourne Australia
    2014 FE 350, 2011 Meo.
    67 CR250, 71 400 Cross, 78 CR250
    I use No Toil filter oil, and Twin Air filters, i wait until all the filters are dirty then throw them in the washing machine, plenty of washing powder and they come out looking like new!
  20. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I use NoToil too, but don't wanna get shot for putting them in the washer. I use a shallow oil drain pan in the kitchen sink so I've got plenty of hot water to work with. Usually, it makes a couple of nasty rings in the sink, I give it a quick clean and wipe it all down so the missus thinks I'm being helpful.:thumbsup:
    duggoey and shawbagga like this.
