cleaning clutch plates
Discussion in 'Vintage/Left Kickers' started by Ethan Carlyle, Oct 29, 2020.
  1. Ethan Carlyle Husqvarna
    1968 Viking 360
    mini bikes
    Any recommendations for cleaning these clutch plates and friction plates? The spots you see are light rust. 1968 Husky sat for 15 years. Had to pry the plates off each other with my fingernail. Should I soak in Evapo-rust and then clean with a green scotch-brite and wd-40? That's how I clean rust off my table saw. Thanks. Here's a pic of the rust.
    https://photos.app.goo.gl/dogmh7yXHJN8gjVD8
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    clutch plates are replaceable, something to consider
    but you can clean those, you want some roughness on the metal and a reasonably clean fiber
  3. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    My 1970 400 Cross plates looked just like that when I refurbished it after years of sitting. I tried cleaning the plates and a light sanding. It was plagued with clutch slippage. Tried different cleaning methods and adjusting, then readjusting the springs, still slipped. I decided it must be the springs, until I talked to John at Vintage Husky. He said just replace the plates and it will work. He was right, new set of plates. Don't know if you'll have the same issues, but my suggestion is like 2premo above, consider a new set of clutch plates.
    2premo likes this.
  4. Ethan Carlyle Husqvarna
    1968 Viking 360
    mini bikes
    Thank you all. I let them sit in evaporust overnight and they seem to be working. But I have not tried them with the engine running yet. Got a bit to do before that. And I've got John at Vintage Husky on speed dial by now (he's very helpful) so I may just get some new plates.
  5. Charliechitlins Husqvarna
    Kimberton, PA
    81 xc250
    78 honda xl125, 2001 Scorpa SY250
    Fibers with brake clean, steels with glass beads.
