Clutch actuation arm-aftermarket?
Discussion in 'Vintage/Left Kickers' started by ruwfo, Feb 28, 2010.
  1. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Guys,
    I just bought a 83 250XC, & the bike's got what i think is an
    aftermarket clutch actuation arm, makes the clutch feel like butter.
    I believe it's because of this, it makes the clutch as good as a
    modern bike?
    Anyone see one like this? I can't believe how well the clutch action
    is :thumbsup: & that's with a so-so cable even.
    Husky John
  2. MAG250 Husqvarna
    Houston TX
    Looks like a stock Husqvarna front brake actuation arm to me.
  3. Long Range Husqvarna
    Looks like a front brake lever that has been adapted.
  4. NFG Husqvarna
    That is slick. Might try that myself. Can you post better pic's and maybe put a ruler in the shot so I can get an idia what the mesurments are?
  5. Up-tite Husqvarna
    Just cut your stock one and add 10-15mm to it and weld it up. Later George
  6. luvwoods Husqvarna
    Zoar, Ohio
    Same thought here, especially after seeing the "pointer" on the end attached to the clutch shaft.
