Clutch adjust
Discussion in '610/630' started by wastewater, Jul 19, 2010.
  1. wastewater Husqvarna
    Australia
    Just put a new clutch in TC610 2000(fibre and steel plates).
    But the grab on the clutch seems right at the end of lever.
    Can it be adjusted so it grabs earlier?
    This hasnt happened on any of my other bikes.
    Do you adjust it at the basket itself?(screw adjustment on the front of clutch).
    Any help would be great.
    Darren
  2. jerbear610 Husqvarna
    Sacramento,CA
    14' WR300, 11' TE511, 06'TE610 sold
    11' Husaberg FE570, 15' Beta 300RR
    Did you try adjusting the cable on the bars? If you screw it in more it will let out
    quicker if that's how you like it. I prefer more how you described as in letting out
    at the end. Makes for easier two finger clutching when you're in tight terrain or in a
    tight spot.
  3. Hennie Husqvarna
    South Africa
    2009 TE610i
    2008 BMW F800GS
    Mine also only takes when the lever is almost against the grip. Tried to adjust by using screw adjuster next to cltch lever, but not much change.
    Maybe getting a two finger clutch lever or sawing off part of the lever?
  4. rancher1 Husqvarna
    WA
    wastewater, you need to adjust the basket first and then adjust the cable lever.
  5. Hennie Husqvarna
    South Africa
    2009 TE610i
    2008 BMW F800GS
    Hi rancher1,
    Please excuse my question-I'm not technical at all. What is the basket you are referring to.
    I (we) have adjusted the adjusting screw anti-clockwise at the clutch lever so theat the screw is almost all the way out, and still the clutch takes/releases when the lever is quite close to the grip.
    Ideally I would like the clutch to take/releases when the clutch lever is almost fully released i.e as far away from the grip as possible to make two finger operation easy. Currently I still have to use all fingers to operate the clutch lest the lever pinches my last two fingers.
    What do I have to do to fix this?
  6. Yossarian Husqvarna
    the 'Ha
    2008 TE610
    Multistrada 1200 Enduro; Tiger 800XC
    There is another clutch adjustment on top of the crankcase.
    Or it could be that your cable has stretched?
