Clutch Adjustment Frozen
Discussion in 'Vintage/Left Kickers' started by endurokids, Jan 28, 2017.
  1. endurokids Husqvarna
    Wisconsin
    250WRX, CR167, 83 430WR, TE449
    75 Guzzi 850T
    Any ideas on how to loosen the clutch adjustment nut and allen screw?
    We keep bending our allen's and even tried heating the nut with a propane torch to no avail.
    What should the freeplay be at the engine lever?
  2. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    Did you use a small allen in the hole off to the side of the jam nut?
    That is how to hold it then crack the jam nut free, then turn the allen and shaft to make adjustments
    2premo and justintendo like this.
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    freeplay according to manual is about 4-5mm at lever tip
    2premo likes this.
  4. Bigbill Husqvarna
    '83 250wr
    0 right now
    If it's assembled I put a Allen wrench in the hole to hold the little circular bearing plate from turning. Then I put a 10mm box wrench on the nut. And a Allen wrench on the set screw. Now turn the jam nut to loosen it not the Allen screw. I adjust mine about 1/8" at the clutch release lever on the case this leaves room for the expansion of the rod.
  5. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    Probably loctited on, remove clutch springs disassemble mechanism use a vice and vice grips replace allen adjustment screw reasssemble and adjust.use med strength thread lock.
    Bigbill and Joe Chod like this.
  6. Joe Chod Husqvarna
    upstate NY
    like jo360 said. easier as with pressure plate off you can get right at it and "break it free" in sight ......easier
    Bigbill likes this.
  7. endurokids Husqvarna
    Wisconsin
    75 Guzzi 850T
    Thanks to all.
