125-200cc clutch chatter
Discussion in '2 Stroke' started by gordon lindsay, May 19, 2012.
  1. gordon lindsay Husqvarna
    wre 125
    dtr 125
    As title says my clutch on my wre 125 is quite noisy until the clutch lever is pulled in then it goes away is this normal or will i need a new clutch thanks
  2. dirt-dude Husqvarna
    Pa.
    If its when its in neutral it does it, its likely its the clutch push rod rattling inside the shaft. We've had an 04 thats done it since new
    and still working fine.
  3. gordon lindsay Husqvarna
    wre 125
    dtr 125
    hi thanks for the reply yes that what mine is doing i,ve put wr friction plates now and ebc hd springs its helped alot but still doing it a little bit
    i think the fact the plates and springs were in need of replacing was causing alot of the noise
