Clutch Creep TE610
Discussion in '610/630' started by Rapid Dog, Aug 25, 2011.
  1. Rapid Dog Husqvarna
    2008 TE610 8500 miles.
    Just went thru this bike and changed the oil, etc.
    Finding neutral is a real beach, guess that's normal.
    However the bike wants to creep/lurch when in gear with the clutch in when starting.
    I've been told the clutch basket has worn parts in particular #26 and #53.
    Any input on this is welcome. I haven't had a clutch apart since the 70's...:confused:
  2. ContraHusky Husqvarna
    My 630 does that and it's brand-new. :p A quirk of the big TE's...
  3. BrandonR Husqvarna
    Oregon
    My 610 has always been like that, the clutch drags even when the lever is pulled all the way in.
  4. boogieman065 Husqvarna
    Clutch creep and difficult shifting while stopped are correlated I believe.
  5. Muddy Waters Husqvarna
    On the islands
    Is it not something you guys can adjust and correct through the clutch perch adjuster?
    When I squeeze the clutch lever on my 08 610sm, somewhere in the middle of the lever stroke it disengages the engine and it stops pulling
    :excuseme:
  6. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    My 610 is the same way, I just roll it forward maybe a foot while messing with the shifter to get neutral. That seems to be enough.
  7. Muddy Waters Husqvarna
    On the islands
    Indeed, rolling into neutral is the easiest way :D
    :thumbsup:
  8. Rapid Dog Husqvarna
    Found out why I was having aproblem. The clutch nut had come loose down on the lower bracket on the motor.
    All good now.
