250-500cc Clutch Drag . . . Still
Discussion in '2 Stroke' started by Saabman82, Sep 3, 2022.
  1. Saabman82 Husqvarna
    1994 wxc 250
    1978Kz650 (810),1976 kz900,1977xs650
    1994 wxc250
    I have recently removed the discs/plates to measure, they are all within spec and have no odd burs or blemishes. The basket isnt all notchy where they contact it either like some pictures ive seen on here. I adjusted the screw/nut at the center that sets the pushrod length for the actuator arm. It is about flush with the nut and i wish it was a bit longer..but it is very close to 90deg when the pressure plate breaks loose. i dont think this is my issue..I have installed a new motion pro terminator cable and adjusted it also. I have just been living with the drag for years and am finally trying to get rid of the excessive drag when the clutch lever is pulled..is it even possible? I have never been able to push the bike in gear with the clutch lever pulled, let alone start it in gear.
    I have physically pushed the actuator arm all the way to its limit just to see if it was possible to disengage the clutch enough. I was still unable to push the bike in gear while pushing the arm....Is there hope? Someone show me the light. What do i need to do?...aside from not trying to push my bike..!
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the problem is pressure plate gap, if ANY of the plates are a little distorted from ANY heat
    besides just replacing the clutch check the parts for flat
  3. Saabman82 Husqvarna
    1994 wxc 250
    Gotcha. Good call. I'll pull it back apart and check. Ill report back. U say ANY heat...does that mean it'll just happen again?
  4. 2premo Husqvarna
    Northern NV
    got my clutch pretty hot one time, it affected it for sure
