Clutch packs te511
Discussion in '4 Stroke' started by norma stitz, Jul 14, 2016.
  1. norma stitz Husqvarna
    SMR511
    Nunya185
    I've resigned to trying a new clutch pack to see if my dragging issues subside as some users have reported. I'd rather not go with OEM because that's where I got into this pickle but I'm having trouble finding sources for aftermarket clutch parts.
    Can anyone suggest suppliers of friction discs and plates that will fit the kymco engines? Are they all the same from 449/511/txc/TC/te/smr?
  2. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    What oil do you use, is it light weight motorcycle oil?
    5w40 or even 0w40?
    Also, have you attempted reshimming the pack to the correct clearances.
    The BMW G450X clutch shim kit is for the same clutch.
  3. norma stitz Husqvarna
    SMR511
    Nunya185
    I've tried mc 5-40, 10-40, and Mobil 0-40. I R&R the clutch 2x and measured pack good in-spec. Bled back and forth many times. Replaced oring in slave. Have master rebuild kit on order but not installed yet. Tried to pull side cover to check shifter parts but requires pulling engine so I gave up and backed off.
  4. norma stitz Husqvarna
    SMR511
    Nunya185
    I've read that new oem clutch pack helped. Not sure how, doesn't make sense, and it's a 300$ experiment I don't really wish to try, but it's about all I have left to do. First I will try the master rebuild. The bike sat for a few years so I suppose it's possible the master is only partially sealing but seems unlikely. The rear brake master was not working when I bought it and I had to massage the seals to get it pumping so maybe this is a similar deal? I dunno but it's getting pretty annoying.
  5. Dangermouse449 Husqvarna
    2011 TE449
    Sounds like you have tried your best.
    One silly question for you, do you have aftermarket levers that may not be giving full stroke at the master cylinder??
  6. norma stitz Husqvarna
    SMR511
    Nunya185
    Stock levers.
    Dangermouse449 likes this.
