Clutch problems HELP!!!
Discussion in 'General (Main)' started by adenike11, Feb 17, 2016.
  1. adenike11 Husqvarna
    2010 510 smr
    2004 cbr 1000rr, 09 r6,2001 xr 650r
    2010 510 SMR just replaced the clutch slave unit with the kit from toxic moto because my clutch pressure would go to zero, after the install I beeded it correctly and got about 4 miles down the road and it went to zero again any ideas? the only way to get pressure back it to pop the top of the reservoir and pump it untill I feel pressure again then another 4 miles or until I have to stop.
  2. adenike11 Husqvarna
    2010 510 smr
    I should add that the mineral oil is still topped off when I pop the top
  3. 268fords Husqvarna
    Powell, Wyoming
    08' TE510'
    Is your master cylinder leaking by chance? I'm not familiar with the toxic moto kit. What comes with that setup?
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Yup rebuild master cylinder, if its not keeping pressure its gunna be back bleeding into your resivour.
