Got just over 70hrs on my wr300 and the clutch racket is starting to rear its head. You know the noise.... the one that quiets down when you pull in the clutch lever and gets loud when the lever is released at idle. All my bikes do it, so I'm not overly concerned but I want to know what it is.
I pulled the basket off yesterday and everything looks great. The pushrod has some uneven wear on the shaft closest to the blunt end, but its nothing too worrisome. Is the noise caused by the shaft rattling around in its bore? And it gets progressively worse as the bouncing shaft further wears away at the bore?
My yamaha has closer to 200hrs and it rattles like no other. Still works perfect though.
What the heck is rattling!?!?
! It could be my teeth that rattles too at my age
