125-200cc Clutch slack after Rekluse install on WR150
Discussion in '2 Stroke' started by BCdirtbikegal, May 3, 2012.
  1. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    '08 KTM sx50 jr, 08 pw50
    I just installed my Rekluse exp 2.0, easy job, but... now I have way too much slack in the clutch. I have adjusted it at the perch and also at the other spot partway down the cable, and added in an extra spacer as directions recommended in the clutch pack under the pressure plate.
    Any ideas?
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    What did Rekluse say about it?
  3. Vinduro Husqvarna
    Mississippi
    Put stock clutch back on.
    IMO
  4. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    think I got it sorted out, had an adjustment mixed up. so will try it tomorrow and see how it is.
  5. barry kaytes Husqvarna
    new jersey
    2012 wr 150
    How many plates did you use.setup sheet was wrong with mine said 5 of each but should be 4.rekluse knows of this and should be correcting the sheet
  6. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Yea we just found that out also on an install for my buddy's 167.
  7. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    oh really? My sheet still said 5 of each so did that. They should be correcting the sheet or sending out a correction page to be added to ones at the dealers. Thanks for the tip, I'll change it today.
  8. john01 Husqvarna
    Powhatan VA
    I ordered one for my 2008 CR165 Monday, it hasn't arrived but Ill check to see how many it say's to install and post it up. Thanks for the tip Barry. Let us know how it all works out for ya BC.
  9. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    I called Rekluse this morning and I guess they have updated the sheet on their website to say 4 of each stock plates, and he figured they would have the updated sheet coming out with new clutches. But thanks again for the tip, this site is great for that! :) I'll try the clutch out this weekend and see how I like it. The plus to all this is I am getting good at taking the clutch apart and back together :p
    wallybean likes this.
  10. barry kaytes Husqvarna
    new jersey
    2012 wr 150
    You will love the clutch.It works great.Makes tight technical riding so easy its like cheating and you can creep up hills at a snails pace if you want.Also impossible to stall.
    BCdirtbikegal likes this.
  11. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    Another question... got it installed with correct number of plates and free play gain where it should be at, and idle adjusted so it idles in gear. Anyone with a 125/150 with this clutch, does it make the clutch harder to pull in? (just compared to stock...)
  12. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    Yeah, I got it mostly because of racing... those last couple laps on a technical course or towards the end of a race when your clutch hand is just done! I have geared the bike right down and that's helped but still times I wish I had the rekluse, so looking forward to riding with it! I had the pro model on my last bike (ktm 250F) and loved it... this bike the clutch is super easy to use as stock, but getting a break in the tight stuff will be nice :)
  13. barry kaytes Husqvarna
    new jersey
    2012 wr 150
    Yes because the rekluse kit springs are stiffer.Only time i use the clutch lever now is to loft the front wheel from almost dead stop.Otherwise I dont use it at all.
  14. BCdirtbikegal Husqvarna
    BC, Canada
    2011 WR 150
    okay cool, thanks :)
  15. Toro618 Husqvarna
    wr125
    I just picked up a new 2012 WR144. Which Rekluse is available for this model. I have never tried an auto clutch, but thinking of putting one in this bike.
  16. Poopy Husqvarna
    Kamloops, BC
    WB165
    What part of BC are you in?? Where can I find a listing for a wr150?? I just looked at rekluses page and couldn't find it.
  17. Poopy Husqvarna
    Kamloops, BC
    WB165
    Ohhhh nevermind I was looking for the Core EXP....lol
  18. wallybean Mini-Sponsor
    Montana
    The one I rode it did seem to be slightly stiffer than stock. But it is using a 2 finger lever with not a great mechanical advantage. Best part is you shouldn't need to use the clutch a whole lot. With the 165, I virtually never use it.
  19. Xcuvator Husqvarna
    Scholls Oregon
    yes
    Do you have a Rekluse in your 165? EXP?
  20. wallybean Mini-Sponsor
    Montana
    Steve,
    I have the EFM auto clutch. Kevin has the EXP.
