Clutch switch bypass
Discussion in 'TR650' started by Al Barkley, Aug 18, 2020.
  1. Al Barkley Husqvarna
    2013 Terra 650
    2005 DRZ400S, 2007 F650GS
    I picked up a 2013 TR650 recently and it appears to be pretty well sorted. One issue I have found is the clutch switch seems to have failed. The bike will only start in Neutral. I haven't looked at the switch or wiring at all yet so not sure if the switch is NC or NO or if there is anything more going on with it I should be aware of before I delete it...
    I thought I'd ask here first to see if there is a commonly used method for disabling/removing the clutch switch? I know it's a safety feature but I don't need it or want it.
    I think I'm liking the Husky so far although I haven't had a chance to even register it yet due to the Covid so I haven't put too many miles on it.
  2. Masterpotter Husqvarna
    South East PA. USA
    Terra 650
    R27, R100, R1200gs,DT1,
    Both the clutch and the side stand switch is usually in the open setting , as in you pull in the clutch and the switch closes and “lets” the ground connect.
    lots of folks remove the kickstand switch , As this often fails after being in deep water, and just connect the wires on the remaining harness. Both of these use part of the same wiring , so if the kick stand is down the bike won’t start in gear. Check this switch or remove it and close the wires First . It is possible that your clutch switch pulled out of the perch or is unplugged.
    PaulC likes this.
  3. Steve Ponce Husqvarna
    Salem, Oregon
    WRX 250 1985 - 2014 TR650
    While we're talking clutch issues can you point me in the direction of a replacement bar assembly, mine snapped off below the mirror threaded boss.
  4. CarstenB Husqvarna
    NL
    F650GS Dakar
  5. Steve Ponce Husqvarna
    Salem, Oregon
    Thank you sir Just the part i was looking for!
