clutch switch
Discussion in '4 Stroke' started by rockrider1, Mar 30, 2010.
  1. rockrider1 Husqvarna
    york,pa
    has anybody ever over ridden the clutch switch ?
  2. jlk_250 Husqvarna
    Minneapolis, MN
    Lots of people have. I just disconnected the clutch switch cable from the harness and made a jumper to replace it so it can be returned to stock at any time. Other people cut the wires and twist them together.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    the ends of mine had male female bullet connectors, I just unplugged and removed the clutch switch end wire harness and connected the male fem bullet connectors on the chassis harness, done. No cutting splicing or jumpers. (2008 TXC450)
  4. rockrider1 Husqvarna
    york,pa
    i like the idea of unplugging at the harness oppose to just cutting the two wires at the clutch and twist....thanks guys
  5. ghte Husqvarna
    Bright, Victoria Australia
    Yep, much better and easier to start in difficult places. Follow the wire to a terminal under the tank and end for end them, do not cut at the lever..
  6. andyman Husqvarna
    YUP. I did the same thing (2009 TXC450).
    Just remove the tank, and follow the wire from the clutch down to the connectors.
