125-200cc clutch
Discussion in '2 Stroke' started by skid, Jul 20, 2010.
  1. skid Husqvarna
    NH
    I'm going to pull out the fibers and steels on my 08 cr 144. Mostly just to check and see how its doing .... what exactly am I looking for???
  2. 2stroked Husqvarna
    B.C. Canada
    Thickness of the plates and discolouration of the metal ones and check the basket/pressure plate for wear
  3. R_Little Husqvarna
    NJ
    Look for big grooves in the clutch basket fingers. A little is okay. Real deep and you may want to remove the basket and file them a little.
  4. skid Husqvarna
    NH
    I took a look.
    The second steel out from the back is very blue, the third out less blue but still discolored the, fourth out somewhat discolored, fifth on out not bad looking .. some black lines, closer you get to the outside of the stack the better everythign looks. I have been advised by a long time enduro rider professional bike wrench to replace the whole stack and springs. A fresh stack from halls is $99, springs a few dollars more .. any cross over parts available?? I have no problem with halls but I'd like to run it this weekend ... if I could find something local.....
