Since I live in the Bay Area, I had the privilege of being the test mule for SME axle sliders Since Husky felt the need to change both front and rear dimensions, both took a little machining to get on, but they should be available soon! The front spacer is easy, the rear blocks took a little work from the 610 size, but Harry said he had some blocks that hadn't gone for anno yet, so if you want a set NAOW drop a line and he may be able to get some soonish. For now, you can just admire mine
can the rear sliders be used to lift the bike with a spool stand? If so, tell Harry I'm in for a set with black blocks as soon as they're available!
Because then they need to come off every time you want to adjust the chain (to torque the axle). Don't see why not! Just contact them from their website and they should get back to you, www.supermotoengineering.com
I ordered mine for my 630 off Motostrano, they were for the 610 Husky,but they fit up fine and look trick too
I think hey just had to be machined down millimetres it was a little tight almost like it wouldn't go, but a couple light taps fit perfect so I say get the 610's SME sliders and you will be good to go.
They cut .020" off of the blocks. It would have taken a BFH to get them in (probably removing all the paint on the swingarm) and chain adjustments would be a bitch...
