Comp Release Cable
Discussion in '4 Stroke' started by cbreakin, Apr 10, 2010.
  1. cbreakin Husqvarna
    SoCal
    2009 TE510
    Is there any harm with removing the manual compression release cable and the lever from an 09 TE510? From what I understand the bike is equipped with an auto decomp system and the manual is just a back-up. If I ever run into a situation where it's needed I can reach down and access the mechanism on the head. Again, anyone see any issues with pulling the cable? Thanks in advance
  2. bmxerdude2087 Husqvarna
    San Francisco, CA
    2008 TE450
    1982 XR200r, 1993 DR350S
    try kickstarting w/o using the cable then make ur decision.
  3. ghte Husqvarna
    Bright, Victoria Australia
    Some guys take them off straight away, there should be no major issues. I have kept mine for the off chance of needing to kick her. I have only done it once in 4000 kms. when the first battery died. Glad I kept the manual decomp them.
  4. cbreakin Husqvarna
    SoCal
    2009 TE510
    Thanks for the replies guys! Its much appreciated!
  5. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    I removed mine. No problems so far.
  6. Ex HVUK Husqvarna
    England
    None
    Occassionally a 510 will come up against compression when you push the starter and need a tap on the manual decomp to get it spinning over. It's worse if the battery is slightly low.
    Dave
  7. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Yes, Ive had that happen with my 450. Hit the button when the piston is on the compression stroke and it barley turns over. The second bump has always worked though...
    I removed mine because I guess Im afraid it wont be always set completely seated where it is suppose to be and cause damage.
