250-500cc Con rod
Discussion in '2 Stroke' started by Mike K, Jul 14, 2014.
  1. Mike K Husqvarna
    Ontario Canada
    wxe 250
    I had a lower rod bearing fail in a 1994 wxe 250 and am having a hard time finding a replacement rod kit would anyone know of cross overs from different years or makes
  2. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    I have the same bike and the same problem.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Try giving Vince at http://www.mrcrankshaft.com/ a call. He did some great work for me. Maybe he can machine a custom crank pin to use a different con rod of equal length that is available
    454x and Motosportz like this.
  4. Mike K Husqvarna
    Ontario Canada
    wxe 250
    may have found the solution to my problem will post more if definite
  5. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
  6. Mike K Husqvarna
    Ontario Canada
    wxe 250
    found a cross over to 2000-2002 KTM sx250 and 2000-2003 exc250 from proX at half the cost of oem
  7. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    Thank you Mike.
  8. rancher1 Husqvarna
    WA
    Have you installed yet or is it a maybe fit ?
  9. Mike K Husqvarna
    Ontario Canada
    wxe 250
    I compared all the measurements and they are exactly the same there is only a slight difference in the length of the crank pin and by compared I mean measured 3 times with two calipers and all the same so I'm pretty confident it will fit
    justintendo likes this.
  10. rancher1 Husqvarna
    WA
    It sounds promising.
  11. Petar Husqvarna
    Pernik, Bulgaria
    Wr 300 94
    What is the situation with the KTM con rod? Is it fit on the Husky Crankshaft already without problem ?
  12. Mike K Husqvarna
    Ontario Canada
    wxe 250
    Still waiting for the parts to show up should know this week hopefully... missing my ride time :(
  13. Mike K Husqvarna
    Ontario Canada
    wxe 250
    Ok rod kit finally showed up and crank is back together with only one very minor mod the crank pin in the kit was around 1.7mm longer nothing the lathe couldnt fix though. Hope this helps anyone with the same problem
    Petar likes this.
  14. rancher1 Husqvarna
    WA
    Give us a ride report on how it runs when you get the chance.
  15. Mike K Husqvarna
    Ontario Canada
    wxe 250
    well got the bike back together and broken in and all seems normal running like it was before
    Petar and justintendo like this.
  16. husk99 Husqvarna
    1994 Huskvarna WXE/WXC250 or CR/WR
    Hi,
    is that Rod the: Pro-X KTM SX 2000-2002
    Part No. Pro-X. 03.6320 ?
    Are the Big/Small end bearings that come with the rod able to be Used,
    without modification?
    How is the bike running now with the rod?
    Cheers
  17. Mike K Husqvarna
    Ontario Canada
    wxe 250
    yeah that is the part # the only thing that had to be modified was the crank pin the ktm one is is a bit longer but the bearings are the same
    haven't had much time to ride lately but been on a few runs and it's running fine
  18. husk99 Husqvarna
    Cool.
    Looks like you found the solution to many peoples problem,
    Finding a rod kit for one of these bikes.
    Thanks heaps.
