convert smr motard to trail!!
Discussion in 'Super Moto' started by huskysmr449, Sep 9, 2014.
  1. huskysmr449 Husqvarna
    smr449
    hi guys
    I have made the switch to motard and have been loving it for the past 9 months but now am missing the trails so I would like to convert my smr449 2001 to trail .
    I was wondering has any 1 don't this before if so would u be able to give me some info on what brake parts ,gearing ect that u have changed
    I would like it so I called do a swap over from time to time
    cheers
  2. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    Just put kenda knob by tires on the 17s take some clicks out of the suspension and ride like that. The wide knob by profile will give you some great traction depending on the trails.
    Tinken and juicypips like this.
  3. darealickt Husqvarna
    2010 SM510R
    2009 WR300
    True, but the 17" front has a harder time getting over tree roots and and stuff. He says its "for trail"... maybe he can tell us what kind of trails he is riding. If it's 4x4 roads then no big deal, but if it's tight single track that's a different story.
    OP, you can always get a 21" front wheel and use that. Of course, you will have to deal with the downsides of the 320 front rotor. To remedy that issue you will need regular TE449 forks and brakes. Really, it just depends on what kind of off roading you are planning on doing with it.
  4. 113moto Husqvarna
    SW Ohio
    2010 smr510
    klx250
    Here is my 2010 smr in the trail set up
    it is fun to switch back and forth but at last there is no place in my neck of the woods
    to ride off road so I never got to use it more used it as a shop project to see how it's done
    268fords likes this.
  5. darealickt Husqvarna
    2010 SM510R
    2009 WR300
    Since you don't use the dirt setup, do you think you might want to sell it?
  6. 113moto Husqvarna
    SW Ohio
    2010 smr510
    klx250
    Yes I have been thinking about that I hate to get rid of it but it only has 95 miles on it
    and I don't use it at all
    the set up is a set of 2008 te wheels with new mt21 pirelli tire's
    arrow single exhaust with te mid pipe to whitch from duals to single
    2012 te speedometer to accommodate the 21 in front rim with 95 miles on it
    A longer chain for a bigger sprocket
    plug and play system it is sweet
  7. darealickt Husqvarna
    2010 SM510R
    2009 WR300
    Only interested in the wheels. The rest doesn't matter to me.
  8. 113moto Husqvarna
    SW Ohio
    2010 smr510
    klx250
    D hit me up and lets see if we can work something out
  9. jimmyc Husqvarna
    pittsburgh pa. USA
    11 TXC449, 09 SM610, WR250, plated
    18YZ250X GS1200 busa duc900SS GG
    works for me! there shinkos $114 for the pair.
  10. huskysmr449 Husqvarna
    smr449
    ok i will look into it cheers guys
