Im about to change the coolant on my TE610 08.After draining the old coolant where should i fill up the new one?To the radiator(probably i guess..)or in the overflow plastic tank right under the radiators??
Yes you want a little coolant in the overflow tank. Just in case you ever have an boil over the hot coolant won't melt the container.
Probably a sucker, but I like Engine Ice. Somewhat "green" and no overheating problems. Expensive, but convenient to use as it comes premixed.
Ok thanks guys.Ive bought Engine Ice too and ill use it for the first time.Hope its actually ok and ''cool''.Thanks...
How much did you pay for the engine ICE? Did you have to mix it, or is it ready to just dump in? Is water wetter the same stuff?
Engine Ice does not need any mixture for use; just pour it in straight from the bottle. Not cheap! Around $18-20 for the small jug that I use. Not the same stuff as water wetter. Water wetter is not by itself an anti-freeze.
