New to this forum Can someone help confirm that the hose kit for 2006 SMR450 is the same as TE, TC 450 and 510? Going to pull the trigger on a new silicon set from ebay but non of the sales appear to mention the SMR model specifically although the six piece kit does look like it would fit Thanks
The TC moto version will be the most stripped down package, there may be extra cut out section pieces for road going gear (thermostat and fan thermos switch for example) on TE and SMR version kits. Physically all those machines are the same, at the tube attach points. Easiest thing is to get the TC version kit and if you have a thermostat or thermo switch you want to retain or use, you can cut it in yourself.
My other suggestion is to use the solid loop euro type hose clamps, because if you use the slotted open cut thread loop type the soft silicone hose outer tube material pushes and cuts through the open thread slots in the hose clamps.
