Counterpoint question about 40mm front forks - how far down in clamps??
Discussion in 'Vintage/Left Kickers' started by GaryM, Aug 30, 2011.
  1. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Please look at original brochure pic of the 430cr How far up or down is everyone
    running their forks in their clamps ?? Looks like a lot here in the pic.
  2. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    My 82 430CR fork are set at 1" above the top triple clamp
  3. pcnsd Husqvarna
    San Marcos, CA
    With the fork caps off and the springs removed, set the fork tubes to just provide clearance between the wheel and the fender. If it rubs a little OK, if it rubs more than that you may take a trip "beyond the handbars" on a big front hit and get swatted by the bike in the process if your'e the unlucky type. Yes, it is about 1 inch, a little less on my bike due to an Acerbis fender.
    Regards,
    Paul
  4. Ron Husqvarna
    Azusa, CA
    Pushing the tubes down will increase the rake which makes the bike turn slower, but improves high speed stability.
    Letting the tubes up through the clamps makes the bike turn quicker, at the expense of high speed stability.
    Its always a compromise and mostly personal preference.
    I have WR forks on my 79 which are 1.2" shorter and I have the 1.25" above the clamps (approx .75" above the tire forks collapased).
    Bike turns awesome and still goes pretty straight in the whoops.
