125-200cc CR 125 09 jetting
Discussion in '2 Stroke' started by rockdancer, Aug 7, 2013.
  1. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    What jetting are you CR 125 guys running ?
    I believe mine is from memory 440 main 35 pilot 5 slide . Tried standard and RM needle .
    Ive had two rides so far and initially thought I had old fuel - it wasn't the fuels fault .
    Still running like crap . Spark plug looks good
    Big bogs in deep sand - cant keep in in the power band.
    When it does come on the power band very short and no over rev - compared to a Wr 125
    ( or my Cr 165 for that matter )
    Tried the RM needle - but needs to be on top ( leanest ) slot to not break up at top - then bogs very badly when not at full revs
    I believe I may need to get a 5 slide and lower needle as per Darttyppts set up
    Tried swapping to older TMX - helped quite a bit - ran a lot better but still some big bogs when it had to work in deep sand
    (That carb was working fine on my 144)
    A bit over it to be honest . may just throw on the 144 kit I before I go any further.
    You definitely cant say that the bog issue is only related to a WR
    Im a bit disappointed with the power delivery though - a bit all or nothing and doesn't feel like it really likes revving like the WR 125 did.
    I think an extra power valve spring may help a bit so that's also something I may try.
    Another option I am thinking is adjusting the ignition timing to retard it slightly - thoughts?
  2. Pedec Husqvarna
    Sask.Canada
    On my stock 2013 wr125 I went to a 450 main, 40 pilot, stock slide and c clip on stock needle (edey 15-74) in middle postion and bike ran great no bog and pulled hard for stock 125.
  3. rockdancer Husqvarna
    4 or 5 slide?
    Running around on normal dirt its fine but under heavy load in deep sand - not fine
    I guess I could also try richer jets but needle wants to be at leanest setting
  4. slo rider Husqvarna
    WA
    2009 WB165
    2007 YZ250
    My '09 WR liked the stock CR jetting listed in the manual. Our climate is a little different up here though, so....
  5. Pedec Husqvarna
    Sask.Canada
    The slide is stock I believe a 4 and I live at 2000 feet above sea level. I was testing bike on sand track and riding it as hard as I could and plug looked nice.
