125-200cc CR 125 Mods
Discussion in '2 Stroke' started by Henner Mx, Oct 26, 2010.
  1. Henner Mx Husqvarna
    Wolcott NY
    Now that the season is over and im moving on to the 2011 CR 150 i thaught i would share my mods that help me get a 2nd place overall for the season in the AMRA/OUTLAW motocross series in the lites expert class ( yes on a 125 ) :applause:. FMF fatyy pipe , custom 5 1/2 inch short silencer with 1" i.d. core , stator and cdi & wire harness off from a 2000 CR250 ( husky ) TMX carb 35 pilot stock 60 needle 4th clip down and 510 main yes a 510 main with the advanced timing curve of the 250 it is a gas eating monster :D. other wise stock no porting or head mods needed. You woods guys would love this it has bottom end like no other 125 and yet revs to the moon 13/50 gearing also. If any one is interested in how these mods came to be contact Joe @ Henner Motorsports 315-576-3488 This is a 2008 CR125.
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    congratulations on your success....
    510 main jet - wow. Whats the CR 250 ignition do ? How did you know this mod would be worth doing ?
  3. surfer1100 Husqvarna
    Ottawa, CAN
    09 WR250, Memories of past tiddlers.
    TM-01 EN 125, 03 125 MX, 09 EN 155
    Very interesting, your making me regret selling my 01 CRs ignition.:cheers:
  4. Pedec Husqvarna
    Sask.Canada
    How can you run a 500-510 main, I was running a 400 main when my bike was a 125 and still running very rich. Also was running 30 pilot. Where did you get your suspension done at sound like you got the 45mm forks figured out. My bike is 2008 cr125 with ohlin rear shock.
  5. bigriver Husqvarna
    Salem
    The 2008 cr125 is awsome. I think it maybe better than the new cr125. I would hate to think that anything could turn better or stop faster than 2008 cr 125. I would put my cr125 up against any wr 144 in a race. Its nice to know that people are trying stuff besides powervalve springs and carbs. I like the thought of the husky 250 iginition. :thumbsup:
  6. Henner Mx Husqvarna
    Wolcott NY
    The stator and cdi puts out almost double the spark energy with a very different timing curve if you were to put these on a bike and not jet it properly you would burn a hole in the top of the piston almost immediatly. Its not as horrible as it sounds you have to remember here in NY its only been in the mid 50s latley so summer temps im down around a 470 main and thats not much different than the 09 and 10 with the new tmx carb. As far as the suspension goes FCR suspension is the place to go when it comes to the 45's with the ohlins shock.
  7. surfer1100 Husqvarna
    Ottawa, CAN
    So you used the 250's stator as well? It fit? I just bought the JD ignition, and an 02 CR stator assembly. I will report when I get a chance.
  8. Henner Mx Husqvarna
    Wolcott NY
    Yes you have to the 250 stator , cdi , wire harness. You have to use the 125 flywheel the 250 will not work. Im gald to see intrest in my mods but im not sure on the jd ignition i did not have one to test and with those having modified timing curves from stock it could be a whole different animal.
    paulb likes this.
  9. paulb Husqvarna
    mass
  10. Vinduro Husqvarna
    Mississippi
    Back in 1982, on my XC125, I had a 38mm Mikuni VM and was running a 530 main jet. Big carbs like big jets.
