125-200cc cr 144 or 165 kit
Discussion in '2 Stroke' started by yetty, Sep 26, 2015.
  1. yetty Husqvarna
    cr 125
    canam ds450xc
    Hi I've recently purchased a 2010 cr 125 that unfortunately after buying i found out requires a new cylinder, ive decided i might aswell put either a 144 or 165 kit in, as i live in australia i can only find the 144 kits over here, does anybody know where i can find a 165 kit on here? Is it definately worth going the 165 kit over the 144? also some advise on which exhausts work best would be great, ive been told over here that the HGS systems work best with the 144 kits but other opinions would be much apreciated! Would the standard system be okay for now? Also will a rejet of the standard carbie be okay? thanks andrew
  2. Tim Randall Husqvarna
    NSW Australia
    Wr125 / WB165
    I went 165 on mine and loved it so much I sold my 2011 husky 310 :O bikes amazing, contact wallybean from this site and he will do everything to help you out :)
    Also highly recommend changing the carby to a lectron, make the bike near on perfect.
  3. Auto5guy Husqvarna
    Yelm WA
    2009 WB165, 2004 WB165, 1984 wr400
    1978 Maico 400, 1974 Penton 400
    Walt has sent other 165 kits to Australia. Go with the 165.
    The KTM 200sx pipe is considered the best match for the WB165 and I believe Walt has a batch that already have the Husky style spigot and the proper mounts welded on
  4. Pedec Husqvarna
    Sask.Canada
    Just do 165 with lectron and 200x pipe great off road bike. if your using for mx or track use 144 works good also seems biggest advantage for 165 is off road where whole set up works on low to mid more but still rips on top butt 144 rips on top also and going faster on track you do not use low to mid as much.
    wallybean and lankydoug like this.
  5. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    yeah these blokes are all correct. 165, lectron & custom fatty pipe if you want max bottom end. still rev hard up top. stock pipe will work ok just not as much bottom. exchange rate not real good anymore but if $ no issue then go the whole lot. guess with all 3 you be looking around $2k delivered though
  6. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    I have nothing to add for all what is said above, it's all said.
    it creates :D:D:D:D:D and you never look back.
    Robert-Jan
    john01 likes this.
  7. john01 Husqvarna
    Powhatan VA
    Yep see post above :applause:.
  8. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Please stop teasing me........165 kit on its way. I'm now at the mercy of UPS. Postal tracking is like an advent calendar without the chocolate - every time I check it feels no closer and no treat.
    If the 165 is half as good as you all say, I'll be happy.
    shawbagga likes this.
  9. Pedec Husqvarna
    Sask.Canada
    The wb165 bike works for off road great and I will quit posting picture haha.
    Oldscool likes this.
  10. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    I just put Walts custom fatty on my 165 today after riding all summer with a 125 pipe and all I can say is the bike is Sick,in a good way!
    john01 likes this.
  11. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    You jus runnin the stock pipe hey Oldscool?
  12. Oldscool Husqvarna
    South Australia
    None
    Yeah I will be for now. As you covered ,exchange rate is a killer and it used all my budget. I'll look at a pipe later.
  13. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Started my 165 yesterday for the first time in months, Still on the old fuel ect as the bike was slung in the back of the gagage with, Bike has always started first or second kick and even after all this time started second kick but mad a loud crack noise on kicking it, wasnt untill I went to restart it later I found out what the noise was :doh::D Good job I have spares - On a side note earlier 125 kick starts although to the eye look the same are slightly different and wont work on 2009 upwards as they hit the frame on the down stroke :thumbsup:
  14. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Lay off the leg weights Johnny boy!
  15. Oldscool Husqvarna
    South Australia
    None
    Hi yetty
    I've sent you a pm with my number if you'd like to chat with someone who has just purchased and fitted a Walt 165 kit.
    Where in oz are ya?
  16. Cheekywig Husqvarna
    Norwich, England
    CR125 2013
    Triumph Street Triple
    Does anyone know where i can purchase the 144 kit for my 2013 CR125? Thanks
  17. Oldscool Husqvarna
    South Australia
    None
    Hi yetty,
    How you going with this?
