125-200cc cr ignition help
Discussion in '2 Stroke' started by Chef, May 23, 2016.
  1. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    It seems I have a gremlin in my cr165. The last two times I've been out riding , when the bike gets hot (riding hard) I lose spark. When the bike cools I have spark again and the bike fires first kick. i went through all the connections and they seem fine. I'm thinking a stator could be going bad (old seems units did this when they got hot) but I'm not sure of the husky units. I suppose I could go through and replace the cap, wire, kill switch and eventually the stator but I really would like to get this gremlin cured first swing.
    Thanks
    K
  2. wallybean Mini-Sponsor
    Montana
    It could be either the coil or the stator wiring having an intermittent short when they get hot. You can get them both hot and when the problem happens check your resistance across the igniter stator coil as well as the upper coil. The stator coil should have 23-28 ohms resistance.
