125-200cc CR sprocket change?
Discussion in '2 Stroke' started by Parfo79, May 12, 2013.
  1. Parfo79 Husqvarna
    S Wales, UK
    '98/'05 CR125, '00 CR250
    many...
    Took my 125 out yesterday and for the trail I was riding (steep hillclimbs and very boggy in places) I was getting very little traction. Should I go from a 13 to 14 on the front or down to a 47 from a 50 on the back?
    Also decided to convert to wr ignition or a fww. Wanted add in the classified section)
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I d ont think gearing is the issue . Id say that changing to a bigger rear spocket may help as you can pull a higher gear - I went to a 52 rear sporcket for hills on a 125.
    Try looking at your choice of tyres, tyre pressure and possibly riding technique- clutch control.
    I dont think the CR loses to much in traction compared to a WR
    A flywheel weight and would be first choice before WR ignition
    Or a 144 or 165 kit
    Parfo79 likes this.
  3. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    I Agree with rockdancer
    tire , pressure in the tire, and ad some flyweight.
    the last one is the ticket you need I think, unless you want to do a more radical approach in getting more displacement
    Robert-Jan
  4. Parfo79 Husqvarna
    S Wales, UK
    many...
    Ive just looked at the gopro footage from my mates bike and my bike looks like it is set up really well apart from the extreme muddy climbs. Going through bogs it looks like the bike is moving along at a good pace so id say it was mostly rider error. Must ride more!!!
  5. rockdancer Husqvarna
    yes riding technique is huge. We do tend to blame our bikes
    You also cant just change the cr flywheel to a wr one - you have to do the whole ignition system
    then you may be less happy with performance -- I believe you need to make a spacer for under the engine cover for a flywheel weight
  6. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    Pin it to win it. That's how I attack hills on my 125 anyway.
    I made the mistake of gearing to 13-48 on mine, figuring it wouldn't make much of a difference. It's great everywhere but on hills in 2nd gear the bike starts lacking power. I end up dumping the clutch, which leads to 8k rpm wheelspin the rest of the way up.
    going to try 12-48.
    Parfo79 likes this.
