125-200cc Cr/wr parts on sms
Discussion in '2 Stroke' started by creamsodauk, Jan 8, 2015.
  1. creamsodauk Husqvarna
    Sms 125
    Honda msx, derbi senda 50
    Hello guys just purchased a cr brake red cover off eBay to find it's far too small
    Iv also purchased a cr-wr rear break lever for my year which hasn't arrived yet
    Do the sms and cr run different break set ups?
  2. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    I would not think so yet during the years there are some differences
    my WR has different rear master cylinder and some minor tweaks are made between the different years when i compare it with the SM
    the WR is from 2002 the SM is from 2011
    which year is your ride?
    I do have some part manuals and its a good way to compare the part nr's there is a lot the same yet some fundamental differences between the models
    brakes are only during the age different so far I have my information
    Robert-Jan
  3. creamsodauk Husqvarna
    Sms 125
  4. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    I got one of those master cylinder tops and it is different on the wre, didn;t fit at all, now I have a wr master cylinder and my caliper running together, it looks like the apico cap would fit it but I've lost it somewhere [the wr was a 2006 being broken] Seller also has a back brake from the same bike which looks almost idential. Only diffrence I can see between the two bikes was the wr's front caliper had a wire built into it, to probably activate the rear brake light, I got rid of it and used a hydraulic pressure switch instead, works much better and more reliably. The newer sms and onwards bikes I cannot be sure on
  5. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    the master cylinders are different from the SM and the WR in the part manuals yet on my WR and SM they are Identical just checked it
    Robert-Jan
  6. creamsodauk Husqvarna
    Sms 125
    How annoying! I could always fit a wr res assuming it uses the same banjo fitment as the am shouldn't be too hard to obtain or if any U.K. guys have one I'm all ears
  7. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    put two vids up for you, shows my standard wre back brake and the wr master on the front with the wre caliper, they both use banjo bolts I think theyre called 3/8ths? Front one of wre original I can't find but it had a screw in hole for a microswitch to do rear light, wr has none so works hydraulicly, you can see the switch in the video as the whole banjo bolt ends in it,
    View: https://www.youtube.com/watch?v=22akvXKdCn4&feature=youtu.be
  8. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
  9. creamsodauk Husqvarna
    Sms 125
    I hadn't even thought about the lack of brake light switch! Hmm these huskys are a pain in the ass for parts I was told cr/wr plastics fit from the same year
    However having had a quick look at the rear fender it doesn't have the cdi mounts Id imagine the sides with fit but it looks like il have to home brew a cdi mount
  10. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    your cdi is in the back?? Mine is down in front of the cylinder
  11. creamsodauk Husqvarna
    Sms 125
    There's a large controller on my rear fender it has a holder etc Iv added a few pics of the bike. Iv just ordered a brand new power valve controler for the husky from eBay aswell 8-)
    Under the front of the clocks are the green rectifier I belive? The cdi is under the seat on the rear fender and Iv taken a pic of the engine area so you can have a ganders
  12. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    I see it, your oil tank and battery location look identical to mine, I think the green thing [recitifier?] is down by the engine too, my voltage meter is on the left hand side of the frame up front. I see how you mean about the rear fender, that's how my 07 rs was, mounted back there, cos yours is so bulky I'm not sure where else you could put it. I would get a universal battery holder off ebay, perhaps you could mount the new wr/cr rear fender, then those wires, could you run them underneath the subframe, through the new fender and bolt the box onto the subframe so it is above the rear wheel? As the wheel won't come right up and hit it unless you bottomed it out over a massive jump. Or see that space to the left of the battery? If you took off that side panel, could you not hang the box down there besides the edge of the air filter? one like this but perhaps bigger
  13. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    oh also you still seem to have a thermostat and thermo hose attached, if yours ever breaks you can also use a cr/ wr cylinder head on it and run with no switch
  14. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
  15. creamsodauk Husqvarna
    Sms 125
    Ah good to know
    The cdi shouldn't be too hard to fit! Your right it's just like an rs with the cdi being so big. It's a pain in the back side not being as popular and easy to get parts as the cr/wr models
  16. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    rs.jpg it's annoying to get parts at best main dealer, I ordered a new gear shifter and 5 weeks later it turned up, it only had to come from italy/ sweden! I had bought a used one by then. Shame cos 2 strokes teach you so much as a rider and the oil tank/ pump was a bonus idea, so much easier than premixing, now ktm took over husky and the new road legal 125's are all premix, just the same as the ktm exc's, not even sure they'll do a tuned down street legal version for learners, it'll all be 30 hp plus. Plan for mine is fit this new piston providing it's the right size, see how long my oil pump works and then put a venhill single action throttle cable on, no more oil pump, also want to spray the wheels properly blue. You can thank the EU for even making the bikes have a cdi like that, all about emission control! My 07 rs was properly shit, beautiful thing, but the pistons kept going, the water pump impeller blew apart, the rear shock snapped, the throttle cable snagged and I had to push it thirteen miles home [no breakdown cover, bad idea] and because of emission aprilia did the cdi so it would bog down below 5500 rpm, and the pv opened at 6, so riding it was continously like torque ok here we go, wait, bog bog, bog, come on! bog! lets go ok here we go vroooom vrooom! oh a corner, out of power, bog, bog...I had no idea about jetting back then but I'd have put on an arrow pipe and got the thing sorted, anyway I swapped it for a cagiva w8 2 stroke, same engine as mito, BIG mistake, it was worth maybe a third of my rs's value, and two weeks later the bottom end seized. Had no bike at all then, sold that for spares, then 2011 bought the husky with 5000 miles on it, best bike I've ever had :D I'll keep it even after it implodes and is beyond repair. I got it stuck down a byway in mud as deep as the top of my boot last xmas, had to leave it overnight but the next day freezing cold it started straight up! I also rode it for 160 miles in 4 hours, didn't miss a beat
  17. creamsodauk Husqvarna
    Sms 125
    Iv had 2 new shape es 125s
    I made both full power and never had any of your issues 8-) pv opened at 8k as it should and mine didn't have the environmental dip at 5.5k
    I also fitted a 34mm carb to my 11 plate and an arrow pipe for fantastic results! Infact in fp I still did 11k on one piston and rings and had 103 on the clocks 8-) loved it but it just wasn't the bike for counting 15 mins to work on
    But hopefully once Iv sorteted my husky issues out it will be far more fun to ride then the rs 8-)
  18. creamsodauk Husqvarna
    Sms 125
    Rather then make a new post ul ask here
    I have one of the fairing bolts in my tank stuck! The bolt and but just spins
    Is it a better ide to sinply pull th but and bolt out of the tank or use epoxy whilst it's in place and let it set ?
    I have tried to pinch the bolt and unscrew the bolt with no lick so far
  19. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    do you mean a side panel bolt is stuck in the fuel tank slot just turning around?? I had that on my rx50 if so, I got thin nose pliers and squeezed the bolt head yanked it out, then got one of those little recangle shape metal things, with a hole for a bolt on one side and the other is like a hole going down into an end so when you bolt it it tightens up? I pushed one of those back in the gap on the tank then screwed a new bolt into that instead, still held as it was bolted in the other end of the panel, if your bolt is still stuck you could try getting a really tiny drill bit, then slowly drill into the head for something more to grip?
  20. Miezie666 Husqvarna
    Germany
    2x YZ 125, 1x YZ250 2005, XT600 2KF
